It is currently Wed Jun 25, 2025 3:56 am
[ 7 posts ] |
Longtail won't stay under water
Drew_johnstone
I just bought a 14' Grumman Jon boat with a 23 HP vanguard go devil longtail. It runs great, but the only problem is it is very difficult to keep the prop in the water, as it is constantly pushing up. It is on a 16" transom. Any tips or ideas to help?
Thu Jul 23, 2015 9:11 am |
256mostwanted
 Re: Longtail won't stay under water
Either to big of a prop or end of your cavitation plate needs to be bent up
Fri Jul 24, 2015 8:21 am |
btmannin
Joined: Tue Jan 15, 2013 5:25 pm Posts: 1723 Location: Oxford/Jackson ms
I wouldn't even look at the prop being the culprit.... 99.9999% chance it's your cav plate.. When your bending it, a little goes a long way. Make 1/4" adjustments until you get it running right. A big crescent wrench will do the job.
_________________ 1436 tin can shoved by a 16 GDLT 16.5x48 running like hell from a built 40 merc
Fri Jul 24, 2015 9:31 am |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
Note " only bend the trailing edge up " a little at a time , tun it check it out. , repeat if you have to .
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
Fri Jul 24, 2015 10:29 am |
aknative
Also, if you tune it to ride just under the water to go as shallow as possible before contacting the bottom with an empty boat, when you load that thing up and slow it down it changes the way the boat rides. I tuned mine with the boat empty, got it perfect! Then loaded the family and all the crap my pregnant wife and 2 year old son and the dogs and on and on and if I didn't keep a constant slight upward pressure on the tiller the prop would pop out of the water. Eventually I realized that it's much easier to tune it for the load I'll carry most and then just lean on it a bit when the boat is empty and I'm coming up on a shallow spot.
Fri Jul 24, 2015 11:09 am |
btmannin
Fri Jul 24, 2015 11:53 am |
Drew_johnstone
Ok thanks, I will try this.
Fri Jul 24, 2015 2:51 pm |
[ 7 posts ] |
Users browsing this forum: No registered users and 42 guests |
