It is currently Fri Jun 27, 2025 12:37 am
Reply to topic  [ 40 posts ]
 Boat won't get on plane in deep water
Post Boat won't get on plane in deep water
I have a 2015 Gator Tail GTR35 with 75 hrs on an 1860 Gator Tail Extreme hull and am only getting 8 to 9 mph with a load of 1 other guy (about 220 lbs), an 80 lb dog, 18 decoys (6 of them teal), guns blind bags and of course myself (190 lbs). Yesterday running a creek that was fairly deep I could only get 8 to 9 mph out of my boat. I played with the trim and had my buddy move all over the boat to see if that would help with no success. Once I exited the creek and rode out to the shallower part of the lake I was able to plane out ok and get about 18 to 20 mph out of it. However once I hit the deep water again it dogs out. Could this be a prop issue? I plan on measuring it this evening, anyone know what dimension on the stock 3 blade prop on a GTR should be? Without my buddy with the same load I can get on plane just fine, didn't have this issue last season that's why I'm thinking it's the prop.
GTB1860 Extreme Series w/ GTR35
Death Waits In The Dark! NSDQ!
Mon Nov 23, 2015 9:54 am
Post Re: Boat won't get on plane in deep water
Seems to be a common problem a lot of people attribute to leaky valves
Mon Nov 23, 2015 9:59 am
If you're going only 8 or 9 mph its got to be something more than just the prop.
Mon Nov 23, 2015 1:25 pm
can you verify the throttle is fully opening? What is your max no load rpm, and your max loaded RPM (at your best speed)?
Mon Nov 23, 2015 1:27 pm
Mon Nov 23, 2015 1:45 pm
Mon Nov 23, 2015 1:49 pm
Mon Nov 23, 2015 1:51 pm
Mon Nov 23, 2015 1:52 pm
I'm gonna guess and say you've got a prop problem
Mon Nov 23, 2015 1:53 pm
what doe your blades measure from center of shaft to blade tips ( 3 blade) or Overall Diameter (2 Blade)?
Mon Nov 23, 2015 1:54 pm
Mon Nov 23, 2015 1:57 pm
Mon Nov 23, 2015 2:44 pm
Mon Nov 23, 2015 2:53 pm
8 mph sounds a lot more then a simple prop problem !
Mon Nov 23, 2015 2:58 pm
take a video of this please, It would be beneficial to help diagnose it.
Mon Nov 23, 2015 3:14 pm
Mon Nov 23, 2015 3:34 pm
Having a similar problem with my boat but don't seem to be as bad as yours. Just bought a new 3 blade 12 pitch prop. 2 people, Hunting load (7 dozen decoys, waiders, guns, ammo, and seats) boat runs fine, add another person and the boat wont get on plane good unless in really shallow water 12-14 mph. Had a stock 3 blade before this one and ran 22 mph all day with 3 people and the same load, not sure what pitch it was but im hoping that is the problem.
Mon Nov 23, 2015 3:36 pm
3 blade 12p is a ton of prop
Mon Nov 23, 2015 5:35 pm
Mon Nov 23, 2015 6:14 pm
Mon Nov 23, 2015 6:21 pm
That high of rpm's, and not getting on step, sounds like a worn prop,
But if you are "Bogging" down, Then it sounds like a clogged jet in the carb.
That has been the problem I've been seeing a lot lately.
Mon Nov 23, 2015 7:56 pm
Mon Nov 23, 2015 8:13 pm
Mon Nov 23, 2015 8:20 pm
Mon Nov 23, 2015 8:30 pm
You've got slippage, either the prop or maybe the belt.
Mon Nov 23, 2015 9:01 pm
so you are saying his timing belt is slipping?
Mon Nov 23, 2015 9:03 pm
Mon Nov 23, 2015 9:11 pm
Tue Nov 24, 2015 6:09 am
Tue Nov 24, 2015 6:56 am
Tue Nov 24, 2015 6:58 am
What is between a timing belt and a v belt
Tue Nov 24, 2015 7:24 am
5.25 = 10.5" OD of prop, new they are 11.25", you are .75" less. You need a new prop.
Tue Nov 24, 2015 7:36 am
get out of here maxxis, I am fishing. I was really going after dguidry because he said the belt was slipping. Now it looks as if i might have some other people
Tue Nov 24, 2015 7:46 am
Tue Nov 24, 2015 8:29 am
Thanks for the diagnosis! Only have 75 hrs on this boat, is this normal prop wear or have I just abused this one? I don't run sandy bottoms however I have stumbled upon some rocky bottoms but I try and get the prop stopped and away from the rocks as soon as possible. I do run stumpy areas and areas with submerged logs.
Tue Nov 24, 2015 8:50 am
Tue Nov 24, 2015 8:58 am
Tue Nov 24, 2015 9:14 am
Tue Nov 24, 2015 11:48 am
The bottom where i run has a lot of sand in the mud and I go through props like nobodies business.
Tue Nov 24, 2015 1:53 pm
http://www.gatorglide.com/
gatorheads@comcast.net
Tue Nov 24, 2015 5:25 pm
Users browsing this forum: No registered users and 73 guests
