It is currently Tue May 13, 2025 12:42 am
Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3  Next
 Toughest lower unit: GD, PD or GT?
Post Re: Toughest lower unit: GD, PD or GT?
My GT and my buddy's PD performed the same in the stumps a few days ago. Was an area with all sunken logs and stumps.
Tue Feb 25, 2014 10:58 pm
40HP Gatortail
Tue Feb 25, 2014 11:19 pm
Wed Feb 26, 2014 7:06 am
The pd will take a beating just as well as a gd. I hunt the same area od does and have hit stuff and would've bet money my whole lower was gone…… and i keep on truckin
1850 & 36pd
Wed Feb 26, 2014 8:47 am
Wed Feb 26, 2014 10:25 am
Wed Feb 26, 2014 10:27 am
1850 & 36pd
Wed Feb 26, 2014 10:55 am
Does just as good, but you gotta take the skeg off every now and then and lay it on the concrete and beat it back flat with a dead blow hammer. :lol:
Wed Feb 26, 2014 11:01 am
:lol: the way it sounds that the new ones are being made that might be a bitch
1850 & 36pd
Wed Feb 26, 2014 11:14 am
Won't have to worry about taking it off to straighten it, the cast will probly grenade itself instead of bending :lol:
Wed Feb 26, 2014 11:18 am
Wed Feb 26, 2014 11:28 am
I find it hard to believe they would make a lower unit change that Takes a step backwards in reliability. There has to be a reason for it and I'm sure it will be some sort of improvement to the motor.
40HP Gatortail
Wed Feb 26, 2014 2:57 pm
Wed Feb 26, 2014 6:04 pm
Wed Feb 26, 2014 6:59 pm
The only time it sucks, is when you dont kill. Its usually a pissed off ride back to the ramp :lol:
Wed Feb 26, 2014 7:04 pm
Wed Feb 26, 2014 7:18 pm
You still got the picture of the outboard prop stuck in one of those stumps with the whole prop shaft still attached? That was some funny shit! :lol:
Wed Feb 26, 2014 8:13 pm
I run a GDSD and i honestly have to say it is tough....the down fall is it will beat the S&** out of you when nailing stumps at high speed be ready to RODEO! no problems on the lower Unit the prop has 2 and 3/4 of blades cause the 3rd blade hit a colvert jumping a leavy and i still get 24 loaded down just vibrates bad... any ways i plan on getting a new prop and hitting more stumps in a few days. I have lots of freinds with MB and the cases (lower Unit Housing) crack constantly and are having to JB weld them up. I went with the Galvanized GDSD cant go wrong
Wed Feb 26, 2014 10:04 pm
Wed Feb 26, 2014 10:15 pm
Another mystery solved. Case closed. Next question?
Wed Feb 26, 2014 11:13 pm
40HP Gatortail
Wed Feb 26, 2014 11:18 pm
Barnes, I didn't know MudBuddy had a 3-blade prop???
Wed Feb 26, 2014 11:38 pm
Wed Feb 26, 2014 11:52 pm
Wed Feb 26, 2014 11:53 pm
1850 & 36pd
Thu Feb 27, 2014 12:09 am
There it is!!! :lol:
Thu Feb 27, 2014 12:19 am
40HP Gatortail
Thu Feb 27, 2014 12:20 am
Guys I have a dumb question for you. How in the hell and why in the hell are there so many cypress swamps where there are no longer (standing trees)? Were these places logged a long time ago or storms? Just a dumb and curious question?
[color=#80BF00][b]Excel 1860 swv4f4 with GTR35L with stage 1, cam, exhaust, heads
Thu Feb 27, 2014 12:34 am
Thu Feb 27, 2014 12:43 am
10-4. Carry on.
Thu Feb 27, 2014 12:48 am
Pete here is a little local history for you. It is a good read and you will understand why the cypress swamps are the way they are today.
Thu Feb 27, 2014 1:06 am
Good stuff man. Thanks for the read.
Thu Feb 27, 2014 1:17 am
No problem.
Thu Feb 27, 2014 1:38 am
Where I run, its because they damned up a river, to create a lake. All the trees then died, and broke at water level.
Thu Feb 27, 2014 7:49 am
Good Lord indeed, Owen! That video is impressive to say the least... But that looks similar to the stuff we run in with my long tail. There's usually a lot of carp to shoot at underneath all that vegetation. LOL. We get our share of em, even with banging the prop into stumps and spooking them.
And that prop stuck in that stump with the prop shaft intact is a testimonial for why you need a mud motor to run in those stumps.
How many guys here running Gator tails have cracked a lower unit while running in places like owen's video?
Anyone else wanna comment on clutches wearing out/how often they might need to be replaced?
Thanks again for sharing your knowledge of mud motors with a dumbass northerner. LOL...
DW
1856 Go devil / Gator Glided
HD 4000 MB Sport
Thu Feb 27, 2014 5:59 pm
I wouldn't worry about the clutch.
Thu Feb 27, 2014 6:08 pm
The gdsd will perform just as well as your gdlong tail. The got the same basic construction. I would not want a clutch in such a area. The longer output shaft on the gdsd may come in handy if you get high centered. The gdsd handle can be set up to float, you may find that more comfortable than having a soild set up. later this summer I am going to play with a load leveler bag , to make a kind of power trim. I had one on my long tail, the sd will be easier to set up.
JD
Wed Mar 05, 2014 10:43 pm
Wed Mar 05, 2014 11:03 pm
i run a35gdsd on a 1660 gd. run flooded oaks and cypress and creeks with lots of stumps/old logging rd pilings etc. I have put mine through hell and have had zero problems. Think about it, were talking about mud motors here, not porsche's. simple is better. fewer things to break. the manual trim is a complete non issue. easy to figure out. my skeg doesnt really have nic's in it and i have put it through hell. the other brands may be better in other area's, but its hard to argue any of them are tougher than a GD.
2013 1660 Go-devil w 35gdsd
Thu Mar 13, 2014 9:25 am
40HP Gatortail
Thu Mar 13, 2014 9:56 am
Users browsing this forum: No registered users and 104 guests
