It is currently Tue Jul 08, 2025 2:13 pm
Reply to topic  [ 101 posts ]  Go to page Previous  1, 2, 3
 Converting my boat for longtail
Post Re: Converting my boat for longtail
Looks good. Ive got mine just about hulled out. Just put a deposit on a MB 44 H. Did your motor bolt on to the transom or did you have to mount an adaptor palte? Did you add any extra floatation?
Excel 1851vF86 w/ MB 55V
SHIT HAPPENS
Sun Apr 29, 2012 12:44 am
Swamp, when you re-do the floor in alum, put some closed cell foam flotation under the floor and between the ribs. Get a tiny tach to better monitor the motor. That Kohler 27 should not require a squeeze bulb on the fuel line- check all the connections for leaks, leave the vent open when running. Add fuel stabilizer to the gas periodically. Don't bend the side tabs of the cavitation plate just the trailing edge above the prop. You got good advice already; my MB LT has a trim plate so I only have to bend that instead of the whole plate-this could easily be made and added to your plate. Have fun, wear the kill switch lanyard, and easy on the turns! :mrgreen:
Sun Apr 29, 2012 7:04 am
SHIT HAPPENS
Mon Apr 30, 2012 9:58 pm
Negative! That will absorb water and be a pain to remove. I'm talking of a product like Dow Corning's Foamulator foam sheets- you can cut to fit and absorb almost nothing. The first time around I used hard polystyrene sheets and this did not absorb water and it weighs very little.
Tue May 01, 2012 3:24 am
Thanks. Sounds like you just saved me a headache.
SHIT HAPPENS
Tue May 01, 2012 7:23 am
cajun: its real simple, we live back hea', dis' is our home, an' nobody don' fuk wit' us!
Tue May 01, 2012 10:11 am
Absolutely. I keep a backup mechanical Kohler pump- this simply screwbolts onto the cylinder; if you have an electric fuel pump then the bulb is a good idea.
Tue May 01, 2012 10:37 am
Outboards have electric fuel pumps and still use a primer bulb so why not
Wed May 02, 2012 7:34 am
Bulbs are notorious for letting air in the system. On these low pressure fuel systems, a little air can cause a lot of headaches.
Wed May 02, 2012 6:13 pm
Post Converting my boat for longtail
Bye bye longtail.
Check went out today for surface drive.......
Fri May 04, 2012 5:19 pm
Dang! That's the fastest upgrade I've seen! Forget the alum floor. The water level is dropping here, it would not be a good time to run a shortail but you would definitely find out about getting it stuck real good. :mrgreen: Have fun, Swamp!
Sat May 05, 2012 5:23 am
Ha yeh The areas I fish aren't to bad yet but we def need some rain. I can't wait to get new motor. Have to wait 4-5 weeks!
Sat May 05, 2012 5:02 pm
Sun May 06, 2012 7:20 pm
Finally back alive with new motor. Maiden voyage tomorrow!
Fri Jun 15, 2012 2:00 pm
Your dead to us now! :lol:
1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Fri Jun 15, 2012 2:02 pm
Lol I did like my long tail though
Fri Jun 15, 2012 2:27 pm
Awesome speeds, 21.2 with 3 people in deep water
Sat Jun 16, 2012 2:06 pm
That's not a longtail!!!!
lol
B. MacDonald
Mon Jun 18, 2012 5:03 am
I used to have a long tail, too slow!
Mon Jun 18, 2012 6:55 am
Too slow? Are you racing someone? ;)
B. MacDonald
Mon Jun 18, 2012 2:20 pm
Mon Jun 18, 2012 9:23 pm
Users browsing this forum: Google [Bot] and 55 guests
