It is currently Tue Dec 16, 2025 7:36 am
Reply to topic  [ 231 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
 Atchafalaya Basin This Weekend
Post Re: Atchafalaya Basin This Weekend
Calen reverse at any given time at 6000! I keep mine around 5200 in reverse!!
17x48 extreme stage 2 GTR
Mon Oct 15, 2012 11:30 am
Mon Oct 15, 2012 11:41 am
Mon Oct 15, 2012 11:56 am
Or if you keep it there for a long time. i turn up 5200+ running forward lol from time to time no problem, but its not very often
Mon Oct 15, 2012 11:58 am
Thats why i keep saying if someone would try and build a billet backplat/sump for these it may sure the block up enough for them to turn 5000rpms safely...
Mon Oct 15, 2012 12:12 pm
Mon Oct 15, 2012 12:17 pm
Mon Oct 15, 2012 12:29 pm
Mon Oct 15, 2012 12:31 pm
guess its hard to ask much more out of a cheap as motor...
Mon Oct 15, 2012 12:44 pm
I lost two to aftermarket connector rods!!
Mon Oct 15, 2012 12:47 pm
I lost one to 93 octane fuel.
Mon Oct 15, 2012 12:48 pm
Terry you must have run the shit out of your motors, i haven't seen a connecting rod fail yet, at least i haven't heard of any. What rods were you using? was it always a rod to go first or did something else fail like drop a valve, just like that motor that calen has now.
Mon Oct 15, 2012 12:49 pm
EVT nope never dropped a valve. Same side same Place on both rods. What you think did in EVT. All those stage 3 motors
Mon Oct 15, 2012 12:51 pm
ah i see....Well may they rest in piece, now thats what i call getting rode hard and put up dirty
Mon Oct 15, 2012 12:57 pm
Mon Oct 15, 2012 1:01 pm
Cody's mudbuddy was turning well over 6500 at one time, now thats wound up tight
Mon Oct 15, 2012 1:06 pm
Mon Oct 15, 2012 1:10 pm
Mon Oct 15, 2012 1:54 pm
Mon Oct 15, 2012 2:36 pm
Mon Oct 15, 2012 2:39 pm
Mon Oct 15, 2012 2:50 pm
BUCK OFAMA
Mon Oct 15, 2012 2:52 pm
Mon Oct 15, 2012 2:56 pm
BUCK OFAMA
Mon Oct 15, 2012 2:59 pm
I guess the answer is to subjective...
Depends on who has the throttle in thier hands!!! :lol:
Mon Oct 15, 2012 3:00 pm
Only stock part on mine is the crank and fly wheel, only reason i haven't changed the fly wheel is cause its not worth loosing my charging system, plus i hunt and fish out of the boat, but when i wanna play there is plenty of throttle room.
5000 continous is only a matter of time and yes Chauvin it depends solely on who is running the motor, if you don't know what you are doing you'll blow it up in no time but run right it will last you many many oil changes
Mon Oct 15, 2012 3:18 pm
Taken what is your hrs and how old is the mods
Mon Oct 15, 2012 4:29 pm
motor is an 09 put carb on at 20hrs, got tired of fightng the shitty idling of the stock carb and all the hesitation, i ordered the motor with exhaust which was an evt when i first got it. Then at 25hours cody worked the heads at 85 hours we built the motor the way it is now, i have 178 hours as it sits right now, haven't had a rev limiter since the carb was installed at 20hrs.
Mon Oct 15, 2012 7:05 pm
You'd have a rev limiter if you ran stumps and logs.
Mon Oct 15, 2012 7:35 pm
No you wouldn't. means learn to drive. I run over stumps, logs, and all kinda shit I don't over rev it's learn your motor learn your boat and the feel of your motor
Mon Oct 15, 2012 7:43 pm
BUCK OFAMA
Mon Oct 15, 2012 7:48 pm
I run logs and stumps and never had a rev box.
Mon Oct 15, 2012 7:49 pm
Theirs no stumps in la. Lol
Mon Oct 15, 2012 7:50 pm
BUCK OFAMA
Mon Oct 15, 2012 7:53 pm
It's has to be turtles!!
Mon Oct 15, 2012 7:54 pm
One time at band camp!! Shot never mind
Mon Oct 15, 2012 7:55 pm
I didn't have a rev box, And my valves were always screwed!! I think Coe has a video of me in Texas.
Mon Oct 15, 2012 8:00 pm
Mon Oct 15, 2012 8:06 pm
Mon Oct 15, 2012 8:07 pm
BUCK OFAMA
Mon Oct 15, 2012 8:10 pm
