deltaduckmaster
 Re: Atchafalaya Basin This Weekend
Calen reverse at any given time at 6000! I keep mine around 5200 in reverse!!
_________________ 17x48 extreme stage 2 GTR 20X60 DUAL RIG BOWFISHING ADDITION http://www.scalesandtailsbowfishing.com
| Mon Oct 15, 2012 11:30 am |
tchauvin
Joined: Wed Jul 13, 2011 6:23 pm Posts: 4898 Location: Bourg LA
| Mon Oct 15, 2012 11:41 am |
Robn1020
Joined: Mon Feb 16, 2009 6:09 pm Posts: 4232 Location: Cypress, TX
| Mon Oct 15, 2012 11:56 am |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Or if you keep it there for a long time. i turn up 5200+ running forward lol from time to time no problem, but its not very often
| Mon Oct 15, 2012 11:58 am |
tchauvin
Thats why i keep saying if someone would try and build a billet backplat/sump for these it may sure the block up enough for them to turn 5000rpms safely...
| Mon Oct 15, 2012 12:12 pm |
Beadlejuicejr
Joined: Tue Nov 02, 2010 7:11 pm Posts: 1435 Location: Bayou vista, Louisiana
_________________ stage 3 GTR screaming behind the 1848 Garrett Pearce special. GET YOU SOME!
| Mon Oct 15, 2012 12:17 pm |
craig
Joined: Tue Jan 13, 2009 7:53 pm Posts: 7515 Location: Chauvin
_________________ 1750 GatorTail Extreme/Stage 3 37 GTR HD Procrastination is a lot like masturbation. Sure it sounds great at the time but, in the end your only f--k--g yourself.
| Mon Oct 15, 2012 12:29 pm |
craig
| Mon Oct 15, 2012 12:31 pm |
tchauvin
guess its hard to ask much more out of a cheap as motor...
| Mon Oct 15, 2012 12:44 pm |
deltaduckmaster
I lost two to aftermarket connector rods!!
| Mon Oct 15, 2012 12:47 pm |
craig
I lost one to 93 octane fuel.
| Mon Oct 15, 2012 12:48 pm |
take'emgator
Terry you must have run the shit out of your motors, i haven't seen a connecting rod fail yet, at least i haven't heard of any. What rods were you using? was it always a rod to go first or did something else fail like drop a valve, just like that motor that calen has now.
| Mon Oct 15, 2012 12:49 pm |
deltaduckmaster
EVT nope never dropped a valve. Same side same Place on both rods. What you think did in EVT. All those stage 3 motors
| Mon Oct 15, 2012 12:51 pm |
take'emgator
ah i see....Well may they rest in piece, now thats what i call getting rode hard and put up dirty
| Mon Oct 15, 2012 12:57 pm |
deltaduckmaster
| Mon Oct 15, 2012 1:01 pm |
take'emgator
Cody's mudbuddy was turning well over 6500 at one time, now thats wound up tight
| Mon Oct 15, 2012 1:06 pm |
deltaduckmaster
| Mon Oct 15, 2012 1:10 pm |
tchauvin
| Mon Oct 15, 2012 1:54 pm |
Gameover
Joined: Tue Jan 03, 2012 9:06 am Posts: 3673 Location: Prarieville,LA
_________________ 1754 GTR Xtreme CC w/ Purple Kool-aid Additives
| Mon Oct 15, 2012 2:36 pm |
dfou
Joined: Sun Dec 12, 2010 12:38 am Posts: 3986 Location: Pville, La
| Mon Oct 15, 2012 2:39 pm |
take'emgator
| Mon Oct 15, 2012 2:50 pm |
bjg
Joined: Thu Jan 15, 2009 7:34 pm Posts: 882 Location: Ahead of you, with a rubber band turning my prop!!
_________________ BUCK OFAMA
| Mon Oct 15, 2012 2:52 pm |
tchauvin
| Mon Oct 15, 2012 2:56 pm |
bjg
| Mon Oct 15, 2012 2:59 pm |
tchauvin
I guess the answer is to subjective... Depends on who has the throttle in thier hands!!!
| Mon Oct 15, 2012 3:00 pm |
take'emgator
Only stock part on mine is the crank and fly wheel, only reason i haven't changed the fly wheel is cause its not worth loosing my charging system, plus i hunt and fish out of the boat, but when i wanna play there is plenty of throttle room.
5000 continous is only a matter of time and yes Chauvin it depends solely on who is running the motor, if you don't know what you are doing you'll blow it up in no time but run right it will last you many many oil changes
| Mon Oct 15, 2012 3:18 pm |
deltaduckmaster
Taken what is your hrs and how old is the mods
| Mon Oct 15, 2012 4:29 pm |
take'emgator
motor is an 09 put carb on at 20hrs, got tired of fightng the shitty idling of the stock carb and all the hesitation, i ordered the motor with exhaust which was an evt when i first got it. Then at 25hours cody worked the heads at 85 hours we built the motor the way it is now, i have 178 hours as it sits right now, haven't had a rev limiter since the carb was installed at 20hrs.
| Mon Oct 15, 2012 7:05 pm |
OwenDickeson
You'd have a rev limiter if you ran stumps and logs.
| Mon Oct 15, 2012 7:35 pm |
Beadlejuicejr
No you wouldn't. means learn to drive. I run over stumps, logs, and all kinda shit I don't over rev it's learn your motor learn your boat and the feel of your motor
| Mon Oct 15, 2012 7:43 pm |
bjg
| Mon Oct 15, 2012 7:48 pm |
craig
I run logs and stumps and never had a rev box.
| Mon Oct 15, 2012 7:49 pm |
deltaduckmaster
Theirs no stumps in la. Lol
| Mon Oct 15, 2012 7:50 pm |
bjg
| Mon Oct 15, 2012 7:53 pm |
deltaduckmaster
It's has to be turtles!!
| Mon Oct 15, 2012 7:54 pm |
deltaduckmaster
One time at band camp!! Shot never mind
| Mon Oct 15, 2012 7:55 pm |
UNCLE-J
Joined: Fri Jul 24, 2009 7:26 am Posts: 10388 Location: S-Ville, LA
I didn't have a rev box, And my valves were always screwed!! I think Coe has a video of me in Texas.
| Mon Oct 15, 2012 8:00 pm |
Beadlejuicejr
| Mon Oct 15, 2012 8:06 pm |
take'emgator
| Mon Oct 15, 2012 8:07 pm |
bjg
| Mon Oct 15, 2012 8:10 pm |
